Ford Centers
What model Fords had the same bolt pattern as a WD?
I am looking at using Ford Centers with 6 lug rims as I don't need the spin out ability.
The Allis used an 8 inch lug to lug [straight across] and 6 inch arbor. 8 bolt centers for 6 loop rims from many tractors will fit but the older 3000 series down to 8n will not, some Int. and John Deeres like my 1020 have the same center. I have junked 444 Int. with same center and 434 with the small pattern which everything is still 8 bolt but 2 inches narrower. In other words an 8n will have an 8 bolt with lug measurements atraight across of about 6 inches and a 4 inch arbor.
Are your rims good? I have a set of combine tires and rims off of my D17 that I'd trade for your WD spin outs if you are close to eastern Iowa.
AaronSEIA
