Lowering Allis B
Im looking for some information on lowering an Allis B. Id like to lower mine to the same height as and IB. I have never seen one in person so I have no idea how the brake pedal linkages are modified. Any pics or info would be greatly appreciated.Thanks beforehand,Dave
the tractor is lowered by rotating the rear final drive cases 90 degrees forward. That lowers about 7 inches and gives same reduction in wheel base. The brake rod is changed from a straight rod to a quarter circle rod. maybe 1/2 inch diameter with adjustable end.
<a href="http://s436.photobucket.com/user/steve-ill/media/ACIB13.jpg.html" target="_blank">
</a>
Steve thanks for the pic, do you have any of the fender modification or the front spindles? Im assuming the spindles are just cut down with the hole being redrilled.
