Allis 6060 vibration
Chrissub
I just put a new clutch assembly in A 6060 and it now has a vibration at around 1800 rpms. Is this anything to worry about or is this normal for a 6060 or what could cause this. I realize this clutch is sticking out off the flywheel pretty far and if it's not balanced perfect that would cause vibration. Just looking for someone's opinion. Thanks William
I think you have answered your question. If you didn't have a vibration before something is not right with new clutch. May have not been balanced at factory.
Tractor belongs to friend he said it just quit pulling itself. When I tore it down it had sheared the rivets that holds the drive clutch off. I`m just concerned that there`s something else that caused it. It looks like the clutch had already been replaced recently.
When I put a new clutch in my 6060 the parts man said I needed to get the whole assembly. Both clutches, new fingers and throw out bearings.
I also replaced everything you mentioned. The part that worries me is that everything looks like it had been replaced recently and the flywheel also looked like it had just been re-ground. The grind marks are still on it and the pressure plate. You can also see writing on the clutch plate. It makes me wonder if this vibration is what caused the other pressure plate to shear the drive hub off. Thanks
I'm pretty sure that engine is the AC version of the Fiat engine like was used in the Oliver 1365 if so the balancer on the Crankshaft may have gone bad you'll need to pull the oil pan to see.Need to get a parts and service manual to make sure.Does it have the kit on the front of the crank that keeps the crank from coming forward?
