WD45 Trans oil leak
black
Fired up the WD45 and pulled my brothers GTO into the shop . Couple of days later there was 80-90 on the floor ,looks like it's leaking from the clutch shaft . The oil is high in the trans. but low in the hyd trans.So is there a external seal on the clutch shaft or does everything need to come apart. Is the hyd. oil running into the trans through a ruptured seal .
Thanks in advance --Larry --ont.
If you are talking about oil leaking from the rear of the clutch area, it may be the front seal of the Hydraulic Reservoir..
If the Hydraulic reservoir has been allowed to run low of oil, the front seal will not be lubed and will go bad..
Not sure, but lifting the engine may be the easiest way to replace that seal..
Ron.
Yes this makes sense , because the hyd. reservoir is low as we speak and I've topped it up occasionally ---looks like I have a spring project added to my list--I guess that's what keeps us young L.O.L.
Thanks --Larry --Ont.
Hey, if that all it needs, you have something to be proud of..!
These were built better than anything produced today..!!
With no electronics, it will KEEP on running...
Ron..
