Here is an update to a post I had earlier in the week. So my brother got the JD 3020 stuck on Saturday and I hop in the Allis to pull him out and the range gear shift is completely gone. We got it torn down and found a u-bolt that holds the shifter cable in place under the cab had come unbolted. We repaired that, but now we can only shift into high range, trying to shift into low or park seems very difficult and didn't want to force it. We can not even shift the linkage on top of the transmission by hand without any cables attached, so now we are thinking there may be a bigger problem with the transmission, is there anything we should be looking for? Also would it make a difference if tractor was running? When we were troubleshooting the tractor was off.
Thanks,
John
