Is there a adapter to drive a chain drive corn head?
I found a 330 head, it has the four latch pins I need to work with my E. The only problem is I believe it chain drive because it's off a K. Is there a adapter to make it belt or make my combine chain? Also how does the finger roller in feederhouse get driven?
Thanks
Mike
AC had an adaptor assembly which bolted to a later two row wide (KL238) so it could be used on an E. I don't know if it would work on a three row. One of the challenges of the E is that the feeder beater is driven from the header. When putting a corn head on an E, a slip clutch assembly was provided to put on the feeder beater shaft.
