Oil from Air inlet stack
FrankieM
New User
I am prepping my B to pull a hay ride this weekend. I noticed that I have oil coming out of my air inlet stack and running down the tube. Any idea's
Make sure the oil cup is not over full. When the engine is shut off if it rocks back that can blow oil out the inlet. Saw a guy trying to pull start a Cat once, had the trans in reverse. When the engine turned backward it blew a lot of oil out the inlet, right in his lap as the air cleaner was just in front of the operator. He didn't make that mistake again..
When was the last time you serviced the air cleaner?? Good chance you have a lot of mud and water and oil in it if you have not done so in a long time which can cause it to be over full and cause that
