A.C. wd45 hydraulic issue....
ballard304
New User
My hydraulics will lift and hold, but will not release and go down. Was slow coming on but is now complete. Is there a rebuild kit or something I can get? Am ordering a repair manual but the tractor has basically three parts to the hydraulics and Im not sure which one needs it. Any help will be very appreciated. :(
On the battery box, there should be instructions, for setting your hydraulics controls. If not then most manuals have a picture, with instructions in them. The WD shares the same instructions, as the WD45.
Pay particular attention to the linkage under the belly that comes from the drawbar spring. If that linkage is damaged/broken/maladjusted, the pump will pump continuously and never lower the load. Screw "A" should be threaded into the divot on the pump body side to shut off the pump.
that happened to a pal of mine he took it to the dealer, they told him a spring inside the pump was broken and would not let the pump stop pumping.
