Re: A.C. wd45 hydraulic issue....
EricB
09-22-2015 10:40:04
Take a really close look at the control levers on the pump itself. Move the control by the steering wheel in both directions to see what is supposed to manage up and down function. You may likely just need to make an adjustment or tighten a set screw on one of the rods. If it lifts well there is nothing wrong with the pump in terms of hydraulic function. When you go to let it down you're simply letting the oil out of the cylinders.
