DrAllis, and all who helped me, we hooked an electric fuel pump up in series to the inlet of the inj pump. It puts out 6-10 psi, cranked the tractor, and in a short time got fuel comming out the loose inj lines at the injectors. Tightened the lines up and it started, took the electric fuel pump out of the system, and it started and ran great. I suspect we wern't getting the air out of the pump untill we installed the electric one. Now we'll find the hyd leak, and maybe put a clutch in it, the clutch pedal vibrates pretty bad when the tractor is running. A loader with a grapple sure is handy.
