da 6265 with hydraulic brakes and mech parking brake. i replaced brake resorvoir. pedals are to floor. there are two master
cylinders interconnected. itt manual says to breed master first and gives order. how do i know if master is good if it does not
move brake fluid thru it to brake cylinder. ie is it air or bad master cylinder ? also if any problems with brake cylinder i
assume take off brake drum and see if leaks at brake cylinder and verify that it expands. what is purpose of crossover left to
right ? is it to balance or help if one master goes bad ?
