AC 5040 steering leak
keith427
I have an '84 model 5040 with a leak in the power steering at the valve that is on the end of the steering cylinder. It is leaking behind the boot where the nut is loose. I will be getting the tool to remove the arm and boot. Is there an o-ring back there? It also has a random leak where the cylinder shaft screws into it on the right side of the picture.
[/img]
You can view the PS system on the AGCO Parts Books site, Just log in as a Guest, then type in 5040.
Scroll down to HYDRAULIC SYSTEM - STEERING SYSTEM, CYLINDER
..above is a pic of that page.
The Service (Shop) Manual is much better for the 5040. It shows great detail in all the 5040's parts.
Thank you for the info. The diagram is very helpful. Now where would I be able to get the seal kit? Would this be avalable from AGCO? I cant seem to navigate there website for Allis chalmers parts.
