hello, took my 50 WD down to put orings on the sleeves. putting it back together right now, seems like someone must have been inside this engine in the past and few things were messed up. i have the I T shop manuel for it and it is pretty specific about how to orient the pistons, rods and pins, but mine was NOT that way when i pulled them. rod locking bolt is supposed to go AWAY from Cam, right and Alum piston T-slot Away from cam also with the markings on rod crank ends pointing toward cam, with the wrist pins on 1 / 3 dressed to the rear of piston and rod backed against back boss, opposite for 2/4 pin dressed to forward side of piston and rod to fwd boss, at least that is how i interpret the I & T manuel. can you guys tell me if this is correct? i put 50 ft lbs on the conn rod wrist pin bolts, is that too much or ok? i noticed pins must have come loose at some time in past or something as there are scores in two liners that match where the wrist pins would be, guess it must have been like that for years, pins were not touching cylinders when i pulled them this time, so someone must have made some noise long ago and partially corrected it. anyway, back to my question, with my components being assembled backwards like they were, will i have engine balance issues when i put it back together by the manuel? does that wrist pin bolt loosen up ever? is this a problem?
thanks for your help all.
micheal
micheal
