Hi, I apologize in advance that this is a long post, but I feel I need to explain the situation completely in hopes that some of you guys might be able to tell me what's going on with my tractor. I recently bought an Allis Chalmers C with a side mounted sickle mower to mow my 2 acres of hay. It's my first AC tractor and I was very impressed with it for the first crop. It has a magneto and the starter and lights run off a 12V neg ground setup with a generator. For the first crop of hay the tractor started right up every time without even having to choke it! It ran great the first day when I mowed. The next day when I was raking it started to miss, but still kept running and starting OK. I thought maybe it was the gas I was using. I didn't think to buy premium so there was some ethanol in it... maybe 5-10%? A friend also suggested it might be a good idea to buy a Lead substitute to add to the fuel, so I picked some up at the local car parts place and added some to the fuel. While I had it in the garage I checked the plugs and wires and I realized that a couple of plug wires had worked loose so I tightened up the ends and put them back on. The tractor seemed to run fine and I parked it until we were ready for second crop. It seemed to start a little harder when I went out the other day to mow, but it was running OK. I mowed for about half an hour and I had to stop for something and shut the tractor off. When I tried to start it again it would not start... at all. It turns over like crazy with the 12V battery, but wouldn't start. Had my wife pull me back to the shop with the truck so I tried pull starting it and half way to the shop it started. Ran for about 30 seconds then quit. I spent the whole day yesterday messing with it. I found a bad wire from the switch and replaced that. I checked to make sure that gas was getting to the carb and that was OK. When I checked to make sure I had spark I noticed it was weak so I replaced the plug wires, but that didn't help. I tried cleaning the plugs and checked the gaps, but that didn't help either. I finally went and bought new plugs and I drained out the gas and put in fresh Premium gas with No ethanol, installed the new plugs and it started right up and ran like a new tractor!! Again this morning it started right up and I went out to mow again. I had to turn off the tractor for a few minutes while I adjusted the mower. When I got back on the tractor it would NOT start!! It turned over like crazy, but no start. I kept trying and FINALLY it started and ran fine! I got back to the field and just as I started mowing it quit. I'm really hoping to find someone who can tell me what's going on with it!???
