WD45 with mounted 4-row cultivator value?
What is the value of a WD45 with original mounted 4-row cultivator. I would call paint on most of sheet metal 4 out of 10. The battery box is rusted out and the the fenders have a lot of rust around mounts. Tractor ran when parked a year or two ago. Can on exhaust, boot on transmission. Looks like it would run with little efffort. Tank and carb are dry. The cultivator is missing most paint but is complete. Tires hold air they are weather checked but tread is 50%.
Thanks,
Mike
Note to file:
To use the cultivator, you must plant the crop with a four row planter, otherwise you
will be plowing up some of the rows.
Or be an expert tractor driver.
Even taking the cultivator to shows is going to be a problem as it is so wide.
I had a two row cultivator on a D14 and it did an excellent job, was easy to transport,
however, I planted with a two row AC planter.
Just keep in mind, if you do not have all the AC equipment, about all you can do with
the tractor is pull something.
I had a full set of AC snap couple equipment with my D14, Today, unfortunately, most
AC snap couple equipment has gone to the scrap yard.
The cultivator alone is worth probably around $200 more or less, there not rare but also not very common anymore as many have been scraped. The tractor since it is not running is basically worth about $600. At that point it is either a parts machine or a project tractor. When they don't run you don't know what all is wrong or needed.
