Two Way Plow for 1939 B
AZ GARY
We have two single plows that oppose each other so when hooked onto the tractor you have a two way plow system. We seem to have all the parts but don't have a instruction book on how to mount it to the tractor. This is a manual lift, no hydraulics. Anyone have one in the computer you could send to me. Thanks in advance.
Gary
If you have a similar plow to mine I can help you just figured out how to mount mine the beggining of the year.
My plow is an IH 186 two way single bottom plow.
Do you have a picture?
<a href="http://s436.photobucket.com/user/steve-ill/media/rockshaftandwheels004.jpg.html" target="_blank">
rockshaftandwheels004.jpg" border="0" alt="rockshaft photo rockshaftandwheels004.jpg
</a>
It is hard to tell from the picture, but those plows look like they are mounted incorrectly. The plow drawbar should be mounted to the front of the rear drives, not in the rear like the normal drawbar. (The plows look too far back)
(quoted from post at 20:38:13 08/14/15) It is hard to tell from the picture, but those plows look like they are mounted incorrectly. The plow drawbar should be mounted to the front of the rear drives, not in the rear like the normal drawbar. (The plows look too far back)
I'm with you bjb, there are two sets of holes in the final drives; one in back of the axle centerline for the rear drawbar and another set ahead of the axle centerline for the plow drawbar.
When installed correctly, the plow drawbar is a handy step for getting onto the tractor. When we were kids, my brother and I used to ride back and forth to the field standing on each side of the plow drawbar and holding on to the steering column.
