I am looking at a loader on a d15 series 2, and I was wondering if it would fit a series 3 d17. I believe it is a ts-500 industrial loader. It also has a crankshaft driven pump. Thank you.
Check the width of the tractor where the loader mounts. WC, WD, etc. are 19 inches wide, I think D17 is the same. Don"t know about the D15. Might also be a shorter fore/aft dimension where it mounts on the D15. You might also want to consider the strength of that loader, going on a larger tractor.
D-15-17-19 all the same width side frames. Loader will be short to the rear axle, but that is easily blacksmithed.
