Help identify WD Allis year made
Kow Farmer
I am looking for some help on my brother's WD Allis tractor please. I am trying to figure what year his WD tractor is. Engine
serial number is WD302024PA. Is this a valid number? I tried tractordata.com By that website I believe it to be a 1950? Could that
be correct? Thank you.
Kow Farmer Kurt
The tractor serial number is on the left side of the rear end. Just below the brake cover
Engine and tractor sn are not the same. Many 201 engines went to power units, etc., but it can be an approximation of year. Like old says....on left rear vertical face of differential housing. Starts with WD-. 1951 is 72328-105181. Post here if different, or check left side of this page.
(quoted from post at 23:19:08 07/19/15) I am looking for some help on my brother's WD Allis tractor please. I am trying to figure what year his WD tractor is. Engine
Kow Farmer Kurt
The tractor numbers for 1951 are as JMS posted.
About 11 years ago a guy by the name of Bryan Smith went to the trouble of correlating engine numbers to the tractor numbers on WDs and WD-45s. He calculated that engines with numbers 278585-313931 were probably built in 1951.
My '51 WD has tractor #100853 and engine #309267PA which fits in with his calculations.
