Hey guys, I have a question: Earlier this year, I had to put a new injection pump on my 200 Allis. Since pump replacement, I have ran the tractor roughly 12 hours since repair, but have been gaining oil since the replacement (pump went right after I purchased the tractor from my grandpa with about 1830 hours on the clock, typical governor band failure).
At time of pump repair, the oil was diluted a bit (likely from governor band particles plugging the return per my pump rebuilder, causing it to build internal pressure), so I changed it. I've gained about 1" on the stick since the oil was changed.
I blew out the return lines then, so I have no reason to believe they are plugged currently. Tractor runs smoothly, no excess smoke, so I do not believe the dilution to be an injector issue (they were done roughly 25 hours before I purchased it.. One nozzle broke and grandpa had hem all reworked at that time. I don't know how/why it broke, but I recall him having to put a piston and liner in it, and was re-ringed at that time also.. In the last many years, the tractor only saw a few hours a year pulling seed wagons and the like, so it has been a little while).
I'm guessing I rolled one of the cup seals installing the pump, but looking for your opinions, as I'd think if I rolled a seal it would lose prime sitting, wouldn't it?
Thanks in advance, and sorry for my long post.. figured more details are better.
Brad
Brad
