blue water massey
ok so I bought an other WD 1953 per the serial#
has a loader not sure of the make has a pretty beat up blade on it now and the drop bucket is still to get here last pic is of the loader tag what you can see of it
has a home made 3 point
new rear tires tubes and loaded last year
also came with a snow blower and a new set of tire chains
as new tires around here run in the $800 mark $700 delivered (about 200 miles) was not bad I figure
it does run and after draining the tank and fuel lines of crude n water it runs pretty good
going to have to clean up the carb as it's gummed up as well as I'm still getting chunks out the bottom drain
if you look you can see my 1950 WD in the background
also have a 1955 WD45 parts tractor
have the hood as well but I will need to replace the exaust gaskets so will wait to install it later
is the carb correct for this as it's more than twice the size of my other one and there isn,t one on the parts tractor
