I have a Gleaner A combine that has the Allis Chalmers engine on it. The combine is tired and ready to be put out to pasture but the engine runs good and doesn't use much oil. Do these engines fit anything else and would this engine be valuable to someone as a parts engine? The block must have frozen up and broken at some point because there is welding on the side of the block so you probably wouldn't want to use it in a tractor.
Combine is going for scrap and I am trying to decide whether to pull the engine first.
Thanks
Thanks
