I am not familiar with this tractor. We are running a round baler and want the PTO to be constantly running. Does the 170 have a single stage clutch? It seems to stop both the forward movement and the PTO when you push down on the clutch unlike the two stage clutch which stops movement in the first stage and then the PTO in the second or is their a problem with this tractor ? Can the high/low be used to stop movement, leaving the PTO running and then shifted back to forward movement without pushing in the clutch, leaving the PTO constantly running or will that cause damage to the tractor ? Any and all advice welcome on how this tractor operates. Thanks.. Jo
