Robert in Md
My AC B will start with the choke about 3/4 closed and will run only with that choke setting. Took carb
off today and soaked it and blow out all the valves . Put back on , no better. Tractor doesn,t run
good enough to use. What else can I do? Sounds like its not getting enough fuel but its getting into
the carb , a good flow from the tank. It has a castiron Zenith carb. I don,t know what to do next.
Thanks Robert in Md.
