A/C 7020 starter
I was wondering if anyone here knows if a starter from a A/C 200 with the 301 c.i.d. engine will work on a A/C 7020 with the 301 c.i.d. engine. The starter on my 7020 quit and I have a 200 that doesn't run setting out back and the starters look the same to me just don't know if they will swap out ok. both are the Lucas starters.
(quoted from post at 08:19:25 06/24/15) I was wondering if anyone here knows if a starter from a A/C 200 with the 301 c.i.d. engine will work on a A/C 7020 with the 301 c.i.d. engine. The starter on my 7020 quit and I have a 200 that doesn't run setting out back and the starters look the same to me just don't know if they will swap out ok. both are the Lucas starters.
Should be the same
the after market parts book I have shows a different starter for the 200 and the 7020 but it shows both starters fitting on the 8010. ??? wonder why
Thanks for the replies, going to get out there today and swap the starters out. I did notice that most of the parts books show the 7020 starter priced almost twice as much as a starter for the 200, was thinking maybe the 7020 starter has more torque but that don't make sense if the tractors have the same engine. Worth a try anyway.
I have a 200 that had the short starter on it and never would turn over fast in cold. I replaced with a delco off a 190 and turns much better. I have a 7020 junked if you should need a starter. I think it is a bigger starter also. I do not think it looks like the others either.
