Re: Allis Chalmers B clutch
My B also "locks" up sometimes when you push the clutch pedal. The actual clutch release fine, the problem with mine is the drive shaft sometimes binds in the pilot bushing in the flywheel. It is supposed to be lubricated by a wick in the crankshaft but I suspect my wick is not properly lubricating the shaft and bushing. You would have to split the tractor and remove the flywheel to access the wick.
