WD hydraulic fluid change
FrankS
My operators manual says that to completely drain the hydraulic system I need to also drain the pump control housing but it doesn't show or tell me how to do it. Also what is the capacity when draining that housing? Thanks.
Do you know if that is also the case for the WD45? Also, where do you guys get your owners manuals? I've got a shop manual but it's a bit too detailed for a novice.
