1945 Allis B
I have a leak which drips overnight at the clutch drain opening. I am fairly sure it is coming from the transmission
side of the clutch since I have to add a quart of oil to the transmission each year. Does anyone know if engine oil
with stop leak in it will work on the seal? It is more of a nuisance than a big problem.
Thanks,
Wayne
Only thing I have those type of things are good for is to cause a guy lots of $$ down the road due to other problems caused by the stuff
For the transmission to leak there it would have to run down the length of the torque tube. The input seal on the main shaft does wear out and will leak. I just replaced the same seal on my CA
