wd 45 loader plumbing
R&W
i have a wd 45 and i am trying to put a loader on it. the loader only has 1 hose going to it but i am wondering how do you plumb these so the rear lift doesn't go up when you raise the loader up? what is the best setup? pictures please...
The way AC originally hooked that up was to put a tee in the line coming off the right side of the hold control valve, just inside the frame channel, which goes to the right lift cylinder. Therefore the rockshaft was fully raised while using the loader. If you want it otherwise, then you'll have to undo both lift cylinder hoses. I suppose you could install shut off valves, selector valve, or couplers to accomplish your goal.
I have a ball valve in the line for the loader. I can lock the loader up while using the lift arms. Unfortunately the lift arms must work with the loader remote. I suppose you could put valves in the 2 lift cylinder lines.
AaronSEIA
