190 XT vibration
bwlaor
New User
I've got a 190XT that has a significant vibration while in low range, with the PTO engaged. There is no other configuration in which it occurs. Anybody got any ideas where to look?
Strange complaint. The PTO gears are driven by the Low Range gears of the Power Director clutch. Failure of these is very rare. Are you sure it isn't related to the PTO powered implement or U-joint on the implement ??
Since the implement operates at the same RPM (540 tach setting) in high without vibration, and on other tractors without vibration, I suspect
it's not the implement. As soon as I pull the 190 into low, it vibrates. Disengage the Pto, it clears. Put it in high, it clears.
If it was mine, I'd be draining the oil from the torque housing and removing the sump and see how much shrapnel is laying on the screen. I also would be planning on a teardown, because there must be a bearing failing inside.
