Adjustable Wish-Bone On A Allis B
KCTractors
Location
Central Wi
I bought home a 1938 Allis B and it has a adjustable wish-bone axle on it. You can pull out each side about 6 to 8 inches by removing a pin on the axle shaft. I have never seen one like that and you can tell that it came from the factory like that. Anybody want to buy it? The hole tractor that is?
Yes it is factory. They came in 2 widths and had extra tie rods to match the width as the tie bar is curved.
I have one also, but mine has been welded to keep it in alignment. The rear wheel should also be adjustable, with a slightly dished bolt on reversible wheel center.
They were used late 38 and 39, until the box type adjustable front end was built. When they went to the box type, they also used the C rear wheels for more adjustment. LOL Bob
