IB Spindle/ arm
Ted in NE-OH
Former owner has welded top of spindle to spindle arm. I want to replace bushings which requires disassembly of arm from spindle. What is best way to do that?
Most common to grind off the weld. Watch for a thin line to develop....then you know you"re thru the weld. Then you can push the parts apart.
