randystickcandy
New User
Hi. I've had this tractor for 14 years and have mowed all those years with a brush hog.(6 ft wide) The driveline hole of shaft is wallored out. on both the pto shaft and the drive shaft.(Hope I"m calling them the right terms) I bought a used pto gear box and shaft and installed them.
that gear box came off a wd45 gas tractor. In 30 minutes of mowing I hit a couple hard "clumps" and broke the driving gears of the pto assembly of the gear box and the gear in the tractor.
Now I have to replace both gears. Someone said you could take that gear up in the belly of the tractor out without taking the tractor apart (separate the tractor in two halves)
Please give my some sage advice on repairing this tractor!!
