handcrank
I was taking the carb apart for a good cleaning when the little spring clip that goes on the float valve came off. I can,t figure out how it goes back on. Is there a digram that shows how it goes on.? Carb is marvel schebler.Tractor is a 1949 wd. Thanks for any help, Don.
Yes the instruction sheet with a good carb kit will show you just how it goes. Not hard to hook up. You get the U part of it on the needle then slip the ends of it over the float and then set needle and float in place and install the pin. O'Really's sells the Walker Brand kits that are pretty good and have very good instructions.
I found really good instructional youtube videos that show all that, If its a Mavel Schebler type in How to rebuild a Marvel Schebler carb and look the one from mikes carburetors, worked very well for me. The one Video right around the 27 minute mark shows that. I tried to post the link for you. -Travis
Mavel Schebler Rebuild
