1939 B Allis
AZ GARY
Where can I get seals for my steering box, power take off and pulley for this tractor? I did get the motor unstruck so now I
move on to get it running.
A lot of the seals are just common seals used in all sorts of stuff. If you can pull them out and take them to a n auto parts store they should be able to measure them and get you new ones
The original steering box was Gemmer, I recorded the housing side cover gasket AC# 207560 was a piece of 1/8" cork ID 2", OD 2.375".
PTO originally 1.125" shaft, AC seal# 206538, CR# 11800.
Belt pulley AC seal# 207993 if shaft has return oil groove, 225450 w/o groove. CR# 13865
