I gather that sooner or later, every WD45‘s engine needs over hauled - part of the deal when owning an old tractor. Question is - would one typically just go with a WD45 kit or upgrade to a D series engine kit, like for a D17? Would a D17 kit be a drop-in and if so, would the driveline and PTO handle the additional power? Don't know that I'd go that route, unless there was a compelling reason for an otherwise working tractor.
I seem to remember reading one time that a hard worked Ford 8N might need an overhaul every few years, a Farmall H or M could go full time for years. Back in the day, how many hours/years could one expect to get out of a WD45's gas engine full time farming on the family farm?
I've read online some warnings with the AC tractors, be it a WD, WD45 or D series tractor that they can and will jump out of gear when going down hill. We have some hills on our place and jumping out of gear hauling a wagon load of hay would not be good. It seems like some of the threads suggest that 3rd gear is the one likely to jump out of gear. What's the skinny on AC tractors (especially the WD45) jumping out of gear? Is it all gears or one particular one? As a back-up, how are the brakes on the WD45 - LOL.
Weights: How is a WD45 typically weighted? Or were they fine without any weights? If weighted, front suitcase weights or front wheel weights - at the rear, I gather fluid was a given and then rear wheel weights. How much weight would be advisable for the WD45 - if any at all?
Anyone ever retrofitted a WD45 with ROPS?
Any info is much appreciated.
Thanks!
Bill
Thanks!
Bill
