Hand Clutch CA Allis Chalmers
linus342000
New User
How to remove the Hand Clutch on a 1952 CA Allis Chalmers? I have remover the Platform, wheel guard, brake linkage & hand clutch lever. Do I also have to remove the Final Drive Assembly the (Pan, snap ring,gear,another snap ring,bearing cup, bearing cone, oil seal & rear axle) before I can remove the hand clutch, how do you get the seal out & drive shaft?
