wd45 brake repair
Well guys, I got my left brake apart, I couldn't get the bottom pin to move and asked you guys for help, I ended up trying the easy one first, I had been spraying blaster for a week and trying to wiggle the pin, no good, took a torch and heated the lower casting for about 5-7 minutes, got some sea foam deep creep and sprayed on the pin as the casting cooled down several times, about 30 minutes later tried to wiggle the pin with a vise grip, after the second grunt it moved, 3 minutes later it was in my hand, thank you guys for your help, rod
