remote hydraulic
khouse6
first allis W D.
the tractor has a remote hydraulic hook up. where is the lever for this?
how does this work?
Like Old said, same as the lift arms. One thing to remember, the WD used a high pressure (3,500 psi) low volume setup. Putting a "modern" hyd cylinder on them will work, but you need to be very careful not to let the pump hit the end of the cylinder with full pressure. Modern hyd systems run 2,000-2,500 psi. It's probable that the new cylinders are designed to take 2x or maybe even 3x rated pressures, but not something I'd care to chance more than about once. I've run new cylinders on mine and never had any issues, but it's something to keep in mine.
AaronSEIA
Lever as old said. You have to set the pump as per the settings chart on the side of the battery box.
The WD-45 had the addition of a "transport Valve", that could be adjusted for a Delay for the Remote cylinder which
was nice with a Semi-Mounted Plow...or Cultivators...
Ron..
