rosedale123
took the B for a spin down the road. It ran well but I noticed gong up a hill the governor did not open up -- it just kept loosing speed. SHould I expect the governor to open up to attempt to maintain speed? Another thing I notice ( although it may be normal) is when throttling it up using the throttle lever, thru most of the quadrant is is one speed and then jumps to a higher rpm . Normal?
If there is something wrong , where would you start? Linkage? governor spring? would you think something is worn and needs replaced?
thanks for any and all help!
