What size of tire fit 8x24 rim
Colton WC
New User
I need some help. I have a WC with 13 x 24 tires that are in bad shape. The the rim size is 8 x 24. I would like to know what size tires would work on this size rim? Would 12.4 x 24 Goodyear Dynatorque tires fit?
Thanks
The rims of that time were designed to be a lot narrower than they are now. That 13 x 24 now converts to a 14.9 x 24 and you will be OK going with that 14.9, You will not be happy if you go to a midgit size tire on that tractor in that 12.4 size that would have been an 11 x 24 with old size markings or 2" narrower on ground and 4" lower on height.
14.9 is no bigger than his current tires, just a different way of measuring them so only if his current tires rubbed and they would have had to rub when new will the 14.9 tires rub.
