Splitting a B, best way to support torque tube....
PatrickBeth
New User
what's the thinking on splitting a B, and supporting the torque tube half..... Block up under the big nut that ties the front steering? Or support the tube.... Thoughts welcome...
I use wood blocks piled up so they crisis cross each other so as to lock them together. I have also used a chain hoist to hold up both parts.
I have a manual screw jack about 32 inches tall that has a VEE on the top.. A 4 x 4 angle iron about 4 inches wide welded to the top with the VEE up. I set it under the torque tube as far forward as you can get on the tube, without getting into the bell housing area. I have a set of stands that bolt to the torque tube, but it gets close to the motor mount bolts and hard to get a socket on them.
<a href="http://s436.photobucket.com/user/steve-ill/media/6paintside004.jpg.html" target="_blank">
6paintside004.jpg" border="0" alt="number 6 side view paint photo 6paintside004.jpg
</a>
It all depends what is not in use when I am splitting one. Here is one way with a jack and jack stands. I will post pictures with all jack stands also. I always place jack stands under the drawbar to remove the rear tires from the floor or ground.
link to more pictures
