Weight of AC C and CA
Rodger 56
New User
I'd like to pull a C or CA in the 2500# class. Like to know the approx weight of narrow front without driver of each. Tractor data states the CA is
about 500# more. Thanks Rodger
Dean"s book shows 2200 for the C with 9-24 tires, 2850 for the CA, 10-24 tires. No added ballast/weights on either.
My pin hitch model CA weighs about 2300 with 12.4x24 rear tires and narrow front.
This is with the rear rams removed but everything else stock
I am close to 200 so this puts me right at 2500 at weigh in
The front gets real light though which is my downfall. It pulls better in 3000. I also removed the hand clutch
There is another CA that pulls at some of the locations I go to and he is down lower than me as he has a custom hitch, and just about everything on the back removed (fenders, braces, deck, brake covers) and uses a skimpy seat. Like this he has about 150 lbs up front of weights to keep the front down
Thanks for the help. Charlie what is your hitch height, we pull at 19"? I have a AC B that weight is about 2200 bare and I don,t need much on the front maybe 50# on some tracks. thanks again Rodger
(quoted from post at 19:31:25 04/06/15) Mine is set at 20" using the stock setup (drawbar)
Our CA need about 70# in the center to make 2.5K. No problems with the WF staying on the ground except with a hard track. We pull with 16.9 x 24's and it does wonderfully well, very competitive setup.
dgerth
