Mystery AC B clutch can't identify
PatrickBeth
New User
Hi, got a 38 AC B and starting a rebuild, want to buy a clutch pack for it, see lots advertised, but none with the hole pattern that is on mine. Mine has equally spaced holes around the flywheel, the ones I see advertised have 3 sets of holes. Need some help to identify, or do I need to drill and retrofit a newer style... Thanks
(quoted from post at 09:11:49 04/04/15) The hand crank B's had a different clutch from the electric starts.What size is your disk?
Oh that is interesting! Away from the tractor today, but will measure when I get home. Yep, hand crank, you guessed it! Aftermarket parts available for it? I hope I hope I hope...
original clutch I think was 8.5 inch.......... later were 9 inch.. You might have to adapt or drill a few holes, im not that familiar on the 8.5 inch pattern.
So, what's the thinking to get a clutch going in this tractor, buy a 9 inch clutch assembly. And drill out the plate to match the flywheel hole pattern. Throw out bearing will all be good and the tractor will be rolling?
It's a 8 1/2 clutch and 5 inch hole pattern... Know where I can get rebuilt or buy off the shelf?
