A D-19 question
NEKS
A guy ask me if my D-19 was a Series 3. Question is did AC make a Series 3 or 4 in the 19. I never heard of it if they did.
Only 1 Series but early D19 Models didn't have the same hydraulic set up as the later ones.My D19 has the 3 spool valve and a front pump that gives it hydraulics even when the foot clutch is pushed in.
Front pump on a D-19 was an option and combined the flows of the front and belly pumps together. So, they pumped about double with the clutch released and 50% when clutch was depressed. If you are not "teed" into the belly pump flow, someone simply added a front pump to replace the belly pump. In that case, there is no Traction Booster feature, because it was in the belly pump linkage.
