AC G Main Frame
Anonymous-0
What all is involved with swapping out the cast main frame. We have one that the front mounting ears have been broken and brazed. I see that the pedal unit has to come all apart. My main concern is what I can't see on the inside.
Thank you for your help.
Nothing to it, drain the oil
Un-do any hydraulic line if you have them
Drive out the pedal shaft
Remove front 4 bolts and roll away the front
Then remove the rear 4 nuts and remove the housing
Just take your time and support the tranny so it is safe
Easy job
When I was using mine to cultivate pumpkins I would swap fronts back and fourth. Put a jack under the back, remove four bolts, pull one away, pull the other one in place and put the four bolts back in.
