190 XT Fluids?
So I have done a little digging to find out fluid specs for this tractor but haven't come up with much, i have found the two dipstick on the floor (one with ears and other hex head base) and I had heard that the 2 ear one is the rear end differential oil and the other hex base dipstick is the hydraulic/power director oil, but what about the transmision? Is it seperate or same as one of the others?
Anyone that could point me in the right direction on all the fluid check points and what fluids I need to use for each one I'd sure aprecise it.
Hello, if you are sitting on the seat the dipstick
with the left one (hex head) is for the hydraulics
including the rear hitch & remotes, power steering
and power director clutch. The right one is the
transmission and rear end. The hydraulics use
universal hydraulic fluid and the tranny/rear end
uses 80-90 weight oil.
Awesome so if I wanted to drain and refill the transmission and rear end I would pull the plugs for both but it drains the same reservoir that the right dipstick goes into? It's milky white so I wanted to change it
If you drain the rearend, you will get a good portion of the oil
out of the transmission. I am trying to visualize the housing
and can't remember if the casting design will prevent all the
tranny oil from draining into the rearend. You will need to drain
both if that's the case. I wish I could take some pictures but I
am not near one of my 190s right now.
