AC 160 Transmission/Hydraulic Fluid
AC 160 BAMA
New User
I'm referbishing an AC 160 and not sure what transmission/hydraulic oil to use. Originally there was some moisture in the sump and I flushed it several times with universal hydraulic fluid type 303. I cleaned the sump strainer and replaced the high pressure filter. I've only used the universal fluid and since the flush the hydraulic system for the 3 point hitch is slow/weak and only works on high RPM's. I'm wondering if I have a pump problem or should I be using a higher viscosity oil like a 30 weight.
