glennster
just wanted to post back on my neighbors 7060 that would jump out of either low or high range, pulled the floor up and cleaned all the mud and corn stalks out of there, then pulled the cover off the console. the cable that controls the park lock was stuck, and the shifter was out of adjustment to where the neutral position for the shifter to pass thru the gate from hi-low to park was about an inch off. got everything all freed up, and re-adjusted the shift cables. tractor shifts great now. thanks for the help!! (also adjusted the trans brake, no more grinding)
