WD Questions
JF Calhoun
New User
What make and model of front loader works best on a WD?
What is the best way to convert the 2 point Allis hitch to the common modern 3 point hitch ?
Can a hydraulic pump be driven from the front of the engine on a WD?
Thanks!
The absolute best loader is the A-C 400 series called a "445" all hydraulic loader, that includes a front crankshaft pulley driven hydraulic pump. There are several brands of add-on 3 point hitches available for your tractor. Just depends on which one you prefer. Some have a drawbar.....some don't.
I have the snap-coupler conversion, removed the cross-link between the lower arms and put vertical "Elephant Ears" on the sides of the "Bail", to eliminate the sway-chains and it is perfect...
I can still drop the Bail anytime I need, for the plow..and the Traction Booste4r works as manufactured..
Ron.
