Allis One Way and Two Way plows for a B/C
I am going to start looking for a single or set of the plows that mount on the back of the Allis B/C tractors. As far as I know, they are called one way and two way plows...assuming the one way to be a single (right plow) and two way to be a pair, (left and right plow). I know they came in steel moldboards and cast moldboards, and required some hardware to mount. They can be manual lift or hydraulic using the little valve setting under the right side of the seat. A separate plow bar was used, with the drawbar removed. This also meant that there were different plowbars for the B and C since their widths are different.
Anyone have any additional information on them, or know where there are any of the plows or hardware for sale? Anyone have an idea of current value of a single or a pair of these plows, with or without all of the mounting hardware?
Thanks, David from jax
I sold a single right hand plow with at least some of the linkage for
$100 a few years ago if I recall correctly. It came with a package
deal of 2 Bs and the back half of a C that I bought in 2010 or
thereabouts.
Zach
(quoted from post at 17:00:25 03/08/15) I sold a single right hand plow with at least some of the linkage for
thereabouts.
Zach
Thank you Zach!
Was the R-hand plow a steel or cast moldboard type?
David from jax
Actually the only piece that is the same for the B
and C plows is the plow itself. The drawbar, axle
brackets and the depth control set up are all
different. In the Midwest the plows are pretty easy
to find but everything else you need to use one is
tougher. Try to find a complete set up. You should
be able to find a single plow set up for less than
$200 and a set of R-L plows for $300. The plows
only sell for less than $100
I posted a while back with pictures of my 2-way plow mounted on a "B". Note that I do not have hydraulics so my rockshaft is manual lift but the mounting under the tractor is the same. With a single plow only the right (looking at the back) is mounted.
<a href="http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ac&th=132285">Pictures of B with plow</a>
